Gas class a mpg
machunt
we are looking at a 2012 fleetwood bounder with a 80 gallon fuel tank. what kind of mpg can i expect to get? also about how many miles on a tank full?
28 REPLIES 28
machunt
alot of good info as always. we are moving up from a 5th wheel towing with diesel 1 ton dually. we would get around 13 mpg give or take.
dodge_guy
My buddy gets 7 with his 2017 37footer. towing his focus gets him about 6.8.
Wife Kim
Son Brandon 17yrs
Daughter Marissa 16yrs
Dog Bailey
A bad day camping is
Tal_IL
2010 Mirada 35DS with V10. We weigh right at 20,000 lbs on the grain elevator scale and I set the cruise control @ 65 mph on the interstate. I don't tow a toad. I keep a log of gas and mileage. Over the last 12,000 miles we have gotten 6.77 mpg. We do use the generator a fair amount and if I deduct out estimated generator usage, I'd guess we are right at 7 mpg just for travel.
35 miles from Normal, IL. As close to normal as I'll ever be.
2006 Country Coach Inspire Genoa 40ft
nohurry
Good responses so far. Your foot, and even wind direction can affect your mileage. Your wise to budget, and plan for expenses, but hereโ€™s my philosophy; I figure on worst case scenario, say 6 mpg, use a high amount per gallon for a total needed for the trip, then I donโ€™t think about it. We just go, and enjoy.
Carl
2007 National RV, Sea Breeze
Rick_Jay
I would expect 6-7.5 mpg depending upon the chassis rating & gearing, whether your towing or not, lots of generator use or not, and level or hilly terrain. If you can get REAL 100% gasoline with no ethanol, bump that up to 6.5-8.5 mpg depending upon the above.
In any case, if you get more than the lower numbers of the estimates, you'll be pleasantly surprised. But don't expect it! ๐Ÿ™‚
Oh, the generator pickup tube is usually set so that the generator cuts-off when the gas tank is down to about 25% full or 20 gallons left. If you're using the generator while travelling as is commonly done during the hot summer months, you'll want to make sure you refuel BEFORE you dip down to that level.
So, from a full 80 gallon tank, plan on refueling after about 50 gallons of driving, or 300-350 miles of driving. Usually, I start looking for gas stations when I pass the 300 mile point on a tankful.
~Rick
2005 Georgie Boy Cruise Master 3625 DS on a Workhorse W-22
Rick, Gail, 1 girl (27-Angel since 2008), 1 girl (22), 2 boys (23 & 20).
2001 Honda Odyssey, Demco Aluminator tow bar & tow plate, SMI Silent Partner brake controller.
rk911
FIRE UP wrote:
rk911 wrote:
we average roughly 6-mpg
Wow,
Someone that's honest about mpg.
Scott
thanks but no point in fudging.
Rich
Ham Radio, Sport Pilot, Retired 9-1-1 Call Center Administrator
_________________________________
2016 Itasca Suncruiser 38Q
'46 Willys CJ2A
'23 Jeep Wrangler JL
'10 Jeep Liberty KK
& MaggieThe Wonder Beagle
FIRE_UP
Wow,
Scott
Scott and Karla
SDFD RETIRED
KI60ND
STBRetired
With the toad, 6.8 MPG running 65 - 70
Without the toad, 7.2 MPG running 65 - 70
Best ever? 9.5 MPG No toad, running 55 on the interstate.
1999 Newmar MACA 3796 F53 6.8L
2016 Ford Edge Sport
Roadmaster Sterling A/T with Brake Buddy Select
rk911
Rich
'46 Willys CJ2A
'10 Jeep Liberty KK
wildtoad
I just finished a 5000 mile trip in my 31 ft F53 based towing a light weight Chevy Sonic, and averaged 7 for the trip. Thus 7x80 = 560. You should do some serious gas station hunting with about 1/4 tank left.
Tom Wilds
Blythewood, SC
2016 Newmar Baystar Sport 3004
2015 Jeep Wrangler 2dr HT
IB853347201
7.5 mpg on a good day. Likely closer to between 6 - 8 depending on where you are traveling. Also depends on model. If you are going are going to tow a car, subtract about .5 mpg.
2010 Suncruiser
Dale_Traveling
There are factors that have a direct effect on mileage. The greatest you can actually control. How heavy is you right foot? Drive it like you stole it maybe 7 but probably less. On the other side drive it like you're mother in law is seated behind you with a sharp stick ready to poke you in the neck any time she feels uncomfortable with your driving and you could see 8.
7.5 is a good average for general planning purposes.
Distance to tank refill, I like to avoid letting the tank get below 1/4 and also normally fill up near the end of my travel day so I have a full tank for the next travel day. I'm averaging 340 miles between fills of 45 gallons or so.
2006 Hurricane 31D built on a 2006 Ford F53
azdryheat
I drive them empty and get 7.5 mpg.
2013 Chevy 3500HD CC dually
2014 Voltage 3600 toy hauler
2019 RZR 1000XP TRE
bgum
