Jan-16-2019 01:48 AM
Jan-18-2019 04:13 AM
Jan-18-2019 01:13 AM
Cloud Dancer wrote:FloridaRosebud wrote:Cloud Dancer wrote:
My F-53 chassis came with anti-roll bars. They were designed as a matched set, and selected to do a good job,... and they did. The front leaf springs were sagging, prematurely. This caused bottoming out onto the rubber stops. It also resulted in some "bump steer". I installed front Firestone airbags to return the ride height to normal, and I added a front panhard link. I also installed wedge shims designed to increase the caster 2 degrees, and added front ballast in order to assure caster authority. Everything worked very well in improving the directional stability. But, I had occasion to drive a large diesel pusher with a Spartan chassis. The rest is history.
I'm trying NOT to drive a DP, as I'm afraid if I do I'll be in debt up to my nose...forever.....;)
Mine came stock with anti-roll bars as well. Rear was about .75" in diameter, and the Helwig is 1-5/8". Made a big difference. The stock front is 1" in diameter, the Hellwig is 1.75". So it stands to reason that the difference in size should help out the front of the MH and we'd be back to a "matched" set, just bigger. My Mechanical Engineer and I discussed the specs of the MH, and he felt like the two biggest issues was the wheelbase was too short for the length, and the MH was not heavy enough for the surface area of the sides and as a result getting pushed around was inevitable.
Al
I screwed up. My Vectra had a wheelbase of 228 inches, giving it a wheelbase-to-overall length ratio of 56%. Yours, with a 208" wheelbase has a ratio of 51%. The rear overhang length of my Vectra was significantly shorter as well. This means that mine had a head start on the chances of having better directional stability. I can now see what drove you to install all the improvements. This also gives me reason to believe that yours might be too light on the front (not enough caster authority) You might want to try a bunch of sandbags up front (just to see what difference it makes).
Jan-17-2019 02:31 PM
Al
Jan-17-2019 10:54 AM
Jan-17-2019 08:55 AM
Jan-17-2019 07:31 AM
Cloud Dancer wrote:
"..the dynamics of suspension". That's fine, except, that in order to find the answers to your questions, IMO you need to isolate the components of your goals. Do you want to concentrate on directional stability first, or do you want to improve on "the handling"?
I should add that I actually was very proud of my 33 ft Winnebago Vectra, when I bought it. It too was on a 208" wheelbase F-33 TRUCK chassis. This chassis is what forced me to try again. It had a long enough wheelbase, but it also had several design deficiencies which made it a poor choice for a motorhome IMO. I could write much more on this subject.
What is YOUR interpretation of "good handling".
What is YOUR interpretation of good directional stability.
Why exactly did you choose to add the rear anti-roll bar?
Do you thoroughly understand how and why "caster" works?
You really do not need to answer these questions. I just wanted you to know some of my thoughts.
Jan-17-2019 06:38 AM
Jan-17-2019 06:23 AM
Jan-17-2019 01:55 AM
Jan-16-2019 05:48 PM
Jan-16-2019 02:40 PM
Jan-16-2019 12:30 PM
Chum lee wrote:FloridaRosebud wrote:
All this improved the handling greatly, and pretty much eliminated the wandering.
So the question - is there any additional improvement to be had adding the Hellwig front anti-sway bar, or have I reached the point of diminishing returns? I would say at this point I've gone from many butt-puckering moments to maybe 2 or 3 over a 300 mile day, as most larger trucks no longer push me around like before. To put a number on it I'd say everything has improved 70-80%. As an aside, I've found that running the driver side air bags at 30psi, and the passenger side at 45-50psi also helped tame the "push" and improved stability.
Thoughts?
Al
OK, you asked for thoughts. Clearly you've changed your suspension, . . . a lot. So, . . . . what's left? Would you consider changing yourself? After everything you've changed, if you are still having 2 or 3 butt-puckering events (your words) each 300 mile driving day, could it be that you are pushing yourself/motorhome too much? You aren't driving a race car on a race track. Just the opposite. As an engineer myself, I can tell you that suspension systems are designed to give the driver appropriate feedback to let them know when they are "pushing it" a little bit too much. When you change the system so that you are driving on the edge without knowing it, don't be surprised when sh*t just "happens" all of a sudden, out of nowhere. That's your design. As always, how you drive is your business and under your control. Not a lecture, . . . . just food for thought, which you asked for.
Chum lee
Jan-16-2019 12:24 PM
FloridaRosebud wrote:rgatijnet1 wrote:
Up you air bag pressure to 80 psi and take it for a drive on the highway. This costs nothing and it may be all that you need to do to minimize sway.
I already tried that and it made the MH ride a bit too hard for my wife and I. A friend said I should just buy a DP and be done with it. I told him if he gave me about $150k I'd be happy to do that....he didn't bite...:)
Al
Jan-16-2019 12:06 PM
Thoughts?
Al
Jan-16-2019 10:20 AM
