Generac Generator
roachcoach
I believe my generator needs a fuel pump as it will run then shut down. Generator model # is 4270-3 Quiet Pact 75D. My question is if you have ever replaced the fuel pump in this generator and is it a diy job. I just replaced the starter in this unit and it was a buger but got it done.
Richard & Rachel
2006 Damon Astoria Diesel Pusher
2004 Jeep Liberty
2 REPLIES 2
roachcoach
Turns out it was the fuel pump so I replaced that and its running fine now.
Richard & Rachel
2004 Jeep Liberty
John_Wayne
Are there rubber fuel lines from the tank to the generator? If so it could just be a bad fuel line sucking air. Take the fuel line off the pump and put a fuel line in a 1/2 gal. of fuel and see if it will run that way if so you have a fuel line leak.
John & Carol Life members
01 31'Sea View single slide, F53 V-10 with 134,000 miles and counting.
2012 Jeep Liberty Smi brake system
Security by Bentley
God Bless
KF6HCH
