โOct-29-2018 10:27 AM
โOct-31-2018 04:36 AM
77rollalong wrote:
there should be one plug for the in house panel, a large 12V battery wire, and the 110v output off the genset. remove and cover up the 12v line, remove and marette the 110v wires, could be a junction box inside the generator door that you can disconnect from there. the control wires just unplug.. it wont affect shore power. Some motorhomes without an automatic transfer switch have a plug inside the shore power box that the shore power cord plugs into, if so the only wire you really have to worry about is the 12V battery feed to make sure it cant short out.
โOct-30-2018 06:04 AM
โOct-29-2018 11:26 AM
โOct-29-2018 10:58 AM
