โAug-03-2013 08:12 AM
โAug-27-2013 12:02 PM
โAug-27-2013 06:56 AM
djedgar wrote:
Yes yellow wire was capped off (and did realize it was for med speed on the fan). The wires from our reversing valve are violet (instructions say also could be black). One is to the T4 terminal and one to the common white wires.
The cooling and heating work fine and no complaints there. I would have never realized the solenoid was energized at rest unless I happen to put my hand on it and it was fairly warm. No humming noise. Maybe this is normal but just does not make sense to me and not the way I would have designed it. I will probably end up shutting off the circuit breaker to that unit while in storage or non use.
I appreciate all your help Doug. You seem to know your stuff. I would be most interested if you can check the next time you do one of these. Easiest way is to plug into shore power and you can hear it click on, or off when disconnecting (assuming no extraneous noise covers it up).
โAug-26-2013 04:56 PM
โAug-26-2013 01:27 PM
โAug-26-2013 12:25 PM
โAug-24-2013 09:45 PM
โAug-23-2013 05:54 PM
Altern wrote:dougrainer wrote:Its the 5-8 years that call attention & disagreement.
Heat Pumps "usually" last no more than 5 to 8 years.
If you had said 8-10 its more palatable and somewhat closer to fact.
Personally, I would have said 10-12.
Its a funny biz though... I've seen really old Carrier's that lasted 30 years and on the other hand, say in the early 80's when for a period, they used Bristol compressors and had a very high failure rate.
โAug-23-2013 02:40 PM
โAug-23-2013 01:54 PM
โAug-08-2013 08:36 AM
โAug-08-2013 04:42 AM
c.traveler2 wrote:dougrainer wrote:
Heat Pumps "usually" last no more than 5 to 8 years. Same for residential Heat Pump units. I state this for people that are using their unit MORE than 8 months a year. Since Heat Pumps cool and heat, they are run twice as much so they will wear out twice as fast. Now, if you full time and stay in a warm climate, your Heat Pump will still be used as much as a standard AC unit. Since Rv's are usually recreational and NOT full time homes, the AC or HP may last 10 years or more, it all depends on how many days a year the HP is used. Doug
Doug, you maybe correct about RV heat pump units lasting 5-8 years, but your giving miss information about residental heat pump units lasting only 5-8 years. There are thousands of residential units that are 25 plus years old and running just fine. I am a HVAC contractor in California, I recently changed out a heat pump system that was 35 years old, so please don't compare a residential heat pump system with a RV heat pump system when it come to longevity.
I do enjoy reading your anwsers to many of the RV related problem and have learned from those answers, keep up the good work.
โAug-07-2013 09:42 PM
โAug-06-2013 06:05 PM
โAug-06-2013 05:40 PM
