โApr-12-2014 04:38 PM
โApr-16-2014 07:43 AM
โApr-16-2014 05:14 AM
โApr-16-2014 02:17 AM
โApr-15-2014 10:00 PM
โApr-15-2014 06:10 AM
โApr-14-2014 07:59 PM
โApr-14-2014 11:14 AM
โApr-14-2014 04:23 AM
โApr-13-2014 09:23 AM
โApr-12-2014 09:36 PM
โApr-12-2014 08:38 PM
โApr-12-2014 08:17 PM
โApr-12-2014 08:12 PM
โApr-12-2014 07:46 PM
Goldencrazy wrote:
When your motorhome was winterized I assume you have a tube that was used to draw the anti freeze into the coach and through all the lines. I suspect that when you or whomever winterized the coach was finished they did not turn the valve to close that tube and connect the water tank. As a result no pressure. The valve is between the water tank and the pump and should have a clear tube attached.
