Holiday Rambler in tank fuel pump quit. Cant find relay?
Broncorambler
In tank fuel pump has quit in my 2004 Holiday Rambler Neptune diesel pusher and cant find the fuse or relay for it.
Monaco has identical model rig under different name, but since out of business there are no techs to contact!
Anyone know of a contact who knows these brands well or where might find an electrical schematic to trace down the fuse or relay?
Hope to avoid dropping tank if can, because scan tool shows no power to the pump. Thanks for any help.
18 REPLIES 18
Broncorambler
Thanks but not a GM. Its a pusher rear engine with a cummins diesel.
No hood. Small fuse box in rear lower battery cabinet and large fusebox in outside cabinet below drivers window.
Fuses and relays labeled but none labeled as fuel pump so kind of stumped.
Just learned Monaco/Holiday Rambler lost all pre 2011 records, diagrams and schematics in a fire darn it, so on my own it appears.
corgidad
Join the group monacoers.org it is a group dedicated to all older Monaco products. There is a wealth of information on the group.
wa8yxm
I do not know the chassis but I do know Workhorse. And GM in general.
On a workhorse front and center.. open the hood and if like me you are six foot. Directly in front (Center) is a black plastic box.. It's in there
On my 1992 Lumina the relays were on the top front rail (Radiator mount rail) passanger side. and it's one of them.
Generally relays are all "Grouped"
Never had a fuel pump relay fail
Did have the starter pilot relay fail (Yup right next door) fixed it (Actually fixed the relay... .Yup I know how to do that).
Horn relay is there too.
HEVAC blower.. Same spot.
