house system excessive draw?
my1972ih
Upon attempting to re-connect the house batteries after the winter, there is a significant spark and I hear something activating or moving under the motorhome. Any guesses? 1988 Winnebago Superchief 31RQ
10 REPLIES 10
tropical36
Start with disconnecting 12vdc loads, one at a time and you might have to go to the fuse panel for this.
Completely disconnect the chassis batteries while you're at, as well and maybe before doing anything else.
wgriswold
My biggest parasitic load was the radio.
2016 Ram 2500 4x4 Laramie
Arctic Fox 25Y
time2roll
240 milliamps is normal detectors and circuit boards even when "off".
That is the exact reason you need to stay plugged in, get solar or disconnect the battery when not in use.
my1972ih
steps were turned off. Could be appropriate parasitic draw. It passes through one of the 30 amp Parallax charger converter DC fuses.
MrWizard
Moderator
Moderator
0.24 amps, aka 240 ma
totally normal, fridge controls, gas sensors etc.. will draw that with no problem
thats normal parasitic draws
I can explain it to you.
1997 F53 Bounder 36s
Jagtech
|Did the step retract/extend when you connected the battery? Maybe the step light is on and drawing current?
Just a thought....
1998 Triple E F53
1995 Jeep Wrangler toad
MountainAir05
Relays that might be sticking. Gas sensors. WE get several sounds when I connect the battery back into the system and turn on the master switch. Cycle them a few times every 10 minutes or so. Hopefully all the relays will settle down.
my1972ih
there is a constant .24 amp draw. Level system is off. Everything I can see is off.
MrWizard
Moderator
Moderator
check that your leveling system switches are ALL off
other than that, you will get a spark from the capacitors in the converter and inverter taking a fresh charge
10forty2
Water pump? Generator fuel pump? Auto steps?
1999 Holiday Rambler Endeavor, 36' Gasser
Triton V10, Ford F53 Chassis
