I'm going to have to gut, and totally redo the inside of my 1979 Itasca 26 footer. Nothing inside works. Tried to turn the lights And got smoke. So I'm going to have to rewire this. The stove is a bomb. I knew this coach had a few problems. But... Anyone know how the outside walls are built? They seem to be like Solid? Was looking for a framing member but can't find any. Also looking to get the generator started.
They are vacuum bonded walls. They have aluminum framing and metal backing for things that may be mounted to the walls and foam insulation. You cannot get inside the wall lIke in a house or motor home with "hung"wall construction which more resembles a house construction.
