โAug-15-2004 01:22 AM
โAug-15-2005 12:48 PM
Noodleman wrote:
Godd advice Griff, I'll look at that soon as I'm ready to take the beast back out on the road. My wife has me working cosmetics at the moment. Did discover one interesting thing when i took the dog house out to look for motor size. There is a HOLE in te transmission housing on the top. It's cut, so I'm guessing it's supposed to be there, I'm just wondering if it shouldn't have a plug in it? I can look down intot eh innards of the transmission. Not sure I should be able to do that.
โAug-15-2005 12:36 PM
โAug-14-2005 05:08 PM
hwguru wrote:
Hey Mr. Mopar!
I've got a question:
I have a 1979 Fleetwood Flair, that did not come with a rooftop A/C unit. I have come across one that i can purchace cheap that does work. Am I going to need to build a frame in the roof to support the weight of the A/C unit? or should there already be one there, and i just need to remove the middle roof vent, and cut out enough rooof material for it to fit?
thanks
โAug-14-2005 09:24 AM
โAug-14-2005 09:12 AM
โAug-14-2005 06:31 AM
donran wrote:
We just bought a 1976 Dodge Sportsman with a Surveyor on the frame. I find it just facinating besides being old and worn, everything seems to work, so far.
What I was curious is is how strong they are. How much weight can the roof hold. Are the various shelving on the inside part of the structure that holds up the walls. Can you strip stuff out, or do the walls fall down?
It came with a manuel for the Dodge truck and its 360 engine. It appears it will need a lot more inspecting and care then a car, and is mush less forgiving of maintenance ignors then a car.
โAug-14-2005 06:13 AM
jrceo wrote:
hi , my mechanic ROBBED my $$.. $100 hr for labor at 10 hrs. dam what a ripp off.. he didn't even get my rv fixed.. the problem is this. when I connect the negative batter cable ,it want to start? why., I changed the resistor and the starter relay. so I don't now what could be the problem maybe a wire along the way??? help. the starter has just been replaced.. what should I be looking for? help. thanks jr
โAug-14-2005 06:02 AM
sandysz wrote:
Mr. Mopar.....Hey.......My windshield wipers did 2 swipes and then quit. I took a new motor and plugged it into the connector and grounded the casing. It did not work. but when the switch is on high the white wire and the purple wire lugs are hot. on low the white wire and brown wire lugs are hot. is that the way that it is supposed to be? does that mean that it is the wiper motor??? Thanks for the help..........Sandy
โAug-13-2005 11:45 PM
โAug-13-2005 07:11 PM
โAug-12-2005 08:08 PM
โAug-12-2005 04:44 PM
โAug-11-2005 07:53 PM
โAug-11-2005 07:34 PM
Southernsuzy wrote:
Hi all we have a 1978 Dodge Free Spirit class C , does anyone out there have one or know anyone withone........ would like to chat on repairs... Suzy...
โAug-11-2005 07:18 PM
