โAug-15-2004 01:22 AM
โMay-26-2005 06:13 AM
โMay-26-2005 05:37 AM
Griff in Fairbanks wrote:xchawk wrote:Mr.Mopar! wrote:
I would guess you have a 440 engine there. That's a good thing.
you might try and retard the timing a few degrees. check the spark plugs for correct heat range and take a good look at them that they are burning correctly, might be running a little lean as well, check the intake manifold bolts for correct tourque and the bolts on the flange of the carb and that the air cleaner is clean. other that that you may need to upgrade to a larger radiator.
Intake was tight, but carb bolts were very loose. Still checking plugs. I'll let you know after my next trip if this helped.
Thanks
โMay-26-2005 05:34 AM
xchawk:
Back around page 24 of this thread, you said your MH was a 1978. If so, look at the the 4th or 5th number of your serial number. (Some Dodges in that era had a single letter model identifier at the beginning of the serial number...others had two letter model identifiers, thereby pushing everything else to the right.)
A - 440-3
D - 440-1
J - 400-1
R - 413-3
My guess is you'll find an A or R...most motorhomes had the -3 engines.
BTW - The 5th or 6th digit should be a 7 or 8, for the year. (Your motorhome maybe a '78 built on a -77 chassis.) The third or fourth digit should be a K or C, which designates the GVW.
If none of the above fits, let me know and we'll try harder to figure it out.
โMay-25-2005 09:08 PM
โMay-25-2005 08:54 PM
โMay-25-2005 08:39 PM
So it's a 440 and not a 400? the parts store keeps saying 400 so is there a difference? The Air cleaner is clean, I'll check the plugs and timming before the next trip.
Thanks
Keith
โMay-25-2005 05:52 PM
โMay-25-2005 01:00 PM
โMay-25-2005 12:27 PM
โMay-25-2005 12:04 PM
Mr.Mopar! wrote:xchawk wrote:
Hmmm still overheating slightly pulling hills and head winds. As soon as I slow down it cools right down to 170. Only thing left to check is the Fan clutch or replace the radiator. Does anyone know how to check the fan clutch or lock it up so I can make sure. And by the way while searching parts I've discovered that instead of the 360 I thought I had, in order to get the right parts I need to request parts for a 400.
Keith
when you say over heating is the coolant boiling out of the radiator or is the temp just increasing to the top end of the gauge?
are you pulling anything when overheating and what is the outside temperature when this occurs?
what parts are you having to get that that fit the 400? are you sure of the engine you have? small blocks have the distributor in the rear of the engine while the big blocks are in the front.
I just inspect the clutch fan for leakage in the front area of the clutch. the fan should turn with some restriction when cool and when warm should turn a bit harder. I don't know of any way to accurately test the clutch on the fan. I have seen a guy drill and put a bolt right thru the clutch to lock it up but I sure wouldn't recommend doing that. it also make quite a roar with the thing locked up like that.
Rodney
โMay-25-2005 06:27 AM
Keith
โMay-25-2005 05:50 AM
โMay-23-2005 06:49 PM
Mr.Mopar! wrote:
I would be looking for a new or good used tank if it were me Don. If there are that many cracks, their may be more to cause you greef down the road.
good luck
โMay-23-2005 06:38 PM
โMay-23-2005 05:55 PM
