HWH jacks question
ricardo
I have a friend that needs to replace the springs on his HWH jacks. I remember reading an article in one of the mags about the best technique to avoid fighting the spring but can't locate it. I did a search on this forum but came up zip. Any help would be appreciated.
Thanks in advance
Rick and Sandy
2010 American Tradition 45ft
425 Cummins
GMC Envoy
3 REPLIES 3
Bumpyroad
when I replaced mine it was a fairly easy task. I hooked up one side spring, put a small bottle jack under the other end of that plate, raised it up bit by bit, when It got high enough slipped the other spring on. no muss, no fuss, easy task.
I had people suggest using a 2 x 4 for leverage, etc. which would be fine if I had superman's help, and three more arms.
bumpy
ccxnola
Read this:
Replace Jack Springs
or - copy & paste:
http://www.rv.net/forum/index.cfm/fuseaction/thread/tid/24120984/gotomsg/25078807.cfm
I saved the link in case I need to do the same!! Have Fun!!
2001 National Tradewinds 7370 mid-entry DP w/CAT 3126b Diesel
Look for the Mardi Gras 'Gators - Laissez le bon temps roulez - Let the good times roll!!
rvten
When I did mine. We slid big washers in the coils. This made the springs longer.
After conn. the spring ends. Just remove the washers.
We also pushed the jacks up in store position. This was the hard part.
Tom & Bonnie
Crossville, TN.
Aspect 29H 2008 Type C
Ford Flex SEL 2010
There is NO B+
