โFeb-09-2018 06:47 AM
โFeb-13-2018 10:45 AM
dougrainer wrote:Thanks, for the info Doug. I never drive until jacks are fully up and storage mode says all jacks are up, then I always turn the Store Mode Off. Iโll have everything gone thru at a RV Shop when I get home!
1. Easy answer--- absolute BS.
2. HOW would he even know if a jack had fully extended too many times???????
3. The Solenoids can be energized up to 15 minutes with no harm. The AVERAGE time a Solenoid is activated is about 2 to 3 minutes.
4. What will cause an HWH solenoid to burn out from too long is if your jack down light came ON on retract and you drove off with that light on and in Store mode. The system will NOT time out if just one jack down light stays on.
โFeb-09-2018 01:58 PM
PastorCharlie wrote:
Perhaps a heavier solenoid would be the fix. Solenoids come in different grades. The better ones are a lot heavier in weight ...more wiring and can be easily noticed by holding them. More expensive.
โFeb-09-2018 01:06 PM
โFeb-09-2018 11:16 AM
โFeb-09-2018 08:16 AM
K Charles wrote:Thanks, Mr. Charles, Iโll look into that when I get back home in April and see if I can speed those jacks up. My thinking until your reply was Iโll just shorten the throw of the jacks? Rooster
HWH doesn't want the solenoid to be energized more then a certain length of time. If your jack takes too long to go up or down it could burn out the solenoid. If that is the case the cause of the slowness should be fixed.
โFeb-09-2018 07:59 AM
