hydraulic levellers. 97 fleetwood southwind motorhome
rvc123
having problems with motorhome hydraulics levellers won't work. just had new rv custom board CB115-rev A replaced with Cb 115 rev p and levellers not working, worked good before, would this be the board or wiring problem. power goes to switch and to levellers, any suggestions muchly appreciated
thanks
rvc123
2 REPLIES 2
OnaQuest
Can you give us more information than "levelers won't work"?
What do they do. Do they even turn ON? Any lights on the panel?
There is no reason why replacing the BCC circuit board should affect the levelers unless someone left a battery cable disconnected.
Gjac
If you can be a little more descriptive of the problem it would be easier to diagnose. What system do you have HWH? Does the pump motor come on but levelers won't move.? Do you have lights to the panel?
