In-dash A/C Blower Motor
papa45
I have a 2000 Pace Arrow Vision on a Ford F53 chassis. Where is the return air intake to the blower?
5 REPLIES 5
RLS7201
Denso HVAC. Right side, under the dash, below where those two hoses attach. Check the carpet in front of the passanger, for 4 screws that hold the bulk head in place.
Richard
95 Bounder 32H F53 460
2013 CRV Toad
2 Segways in Toad
First brake job
1941 Hudson
wa8yxm
I do not have a ford but the location of that air inlet is .. A body builider option per the folks who made mine
On the passanger side floor, under the dash is what appears to be a heat grill, Just like you have in your house... That's it.
MountainAir05
Went and looked at the neighbors, His is about 1 inch from the floor on the firewall. It is 12 long and around 3 inch tall. His is a 2000 pacearrow. If you push you right foot toward the front of vehicle you should hit it with your toe.
papa45
MountainAir05, Can you be more specific? All I can see or feel in that tight area is two ducts going to dash outlets. I found the fresh air intake, forward of the firewall, but I still can't locate the interior/cabin/recirculate air return. Thanks.
MountainAir05
passenger side down low .
