Information Needed for Refrigerator Decision
ncrowley
I am having problems with my Dometic refrigerator. It is great at keeping everything cold and frozen, but there is frost build up in the refrigerator and freezer. In the refrigerator, the fins frost up badly so I need to remove the frost every 5 to 7 days. The frost is building up on the fins on the side where the door opens. In the freezer, the frost is building up where the door opens as well.
I have the battery powered fan to circulate the air and it has not helped. I did the dollar bill test on the door seals and they seem to be fine. I was going to replace the door seals but they do not make them anymore and I would need to replace the doors.
First question: if I keep the refrigerator, should I replace the doors? Is there something else that can be wrong? It is the "pizza" refrigerator with the zig zagged doors.
Second question: I am taking the coach back to Newmar for some updates and I could replace it with a residential refrigerator. However, there is no room to add batteries and I have 4 house batteries. Newmar says that they would not run it off the inverter and it would stay cold when we are traveling. We rarely dry camp - we have dry camped once in the 3 years we have owned it. But I worry about the refrigerator staying cold while on the road for 8 hours. Would I need to run the generator for a while during the day, for example, when having lunch?
Third question: How long do the Dometic refrigerators typical last? The one I have is 12 years old now. Should I be worried about it having to replaced sometime soon?
Thanks for your help.
Nancy
Newmar Northern Star
17 REPLIES 17
dougrainer
1. REALLY need the model number. From your description, it sounds like a 1402 series which has a defrost system.
2. Going to residential, EXTRA batteries are not needed unless you do Boondock, which you do NOT. When in transit and the Inverter is running the refer, The chassis Alternator is supplying the power to run the Inverter and you are not draining the batteries. Also, a residential will NOT run that much to reach the preset temp versus a RV absorbsion refer. So it will not run that much in transit.
3. Frost/Ice buildup is normal. It all depends on the humidity and how often you open the doors.
4. There are 2 drains on the side by side Dometic refers. One at the Bottom back wall of the freezer and the other in the drip pan of the refer evap tray. IF those two drains are not correctly sealed from outside air intrusion, you get excess frost/Ice inside the refer. Doug
wolfe10
Have you done the "dollar bill test" to check the door gaskets-- what did you find.
Is there either a drip loop or restrictor in the refrigerator condensate drain line? If open/no drip loop, it will allow in a LOT of outside air (heat rises).
Brett Wolfe
Ex: 2003 Alpine 38'FDDS
Ex: 1997 Safari 35'
Ex: 1993 Foretravel U240
wolfe10
Brett Wolfe
Ex: 1997 Safari 35'
