For the benefit of anyone following the "handling issues" associated with the E350/E450 chassis. The
cheat sheet for the Ingalls 594 adjustable Caster and Camber sleeves for the E350/E450 has a couple of typos.
1. Drivers Side Caster of +1.0 and Camber of -1.5 is labeled B/K. It should read K/B.
and
2. The Passengers Side Caster of +1.25 and Cambers of -1.0 and -0.25 ar both labeled as T/A. The Camber of -1.0 should read H/R instead of T/A.
I have sent a message to Ingalls Engineering so they might update the pdf file, you would recognize a new file by these changes.
Harvard.
