Aug-16-2020 04:07 PM
Oct-27-2020 06:07 AM
Oct-23-2020 12:54 PM
Oct-23-2020 11:18 AM
Oct-22-2020 09:20 PM
Oct-22-2020 08:35 PM
newizu wrote:Yes and no.
This question is for Tropical36. I am interested in doing what you described you have done to connect inverter as shore power. Would it help if I were to disconnect power bank from main setup and use it as a stand-alone power bank to power the inverter?
Oct-22-2020 08:03 PM
Oct-22-2020 01:30 PM
Sep-13-2020 06:51 PM
Sep-13-2020 05:33 PM
warrenjo46 wrote:EV2 wrote:
One consideration when plugging the shore power cord into the inverter is to turn off the 110 breaker for the converter/charger. If this is not done, the converter will attempt to charge the batteries that supply the inverter. This loop will either use excessive energy at a minimum or trip the inverter. We have labeled our 110 breakers for the converter charger and air conditioning and turn them off whenever plugging into the inverter. Works perfectly. Also may wish to avoid using the microwave.
(Highly recommend a pure sine wave inverter when doing this.)
Yes I did purchase a pure sine wave inverter (2500W).
I will install a normally closed relay in the power to the converter that will be energized to open when the inverter is turned on. That will prevent the converter from trying to charge the batteries with power drawn from the batteries.
My only problem with this plan is "where is the converter?"
After looking at several wiring diagrams and schematics I discovered that the converter is located under the refrigerator behind the grill that looks like the cold air return for the furnace. Since motorhomes are very compact manufacturers need to tuck devices into unexpected places.
Sep-13-2020 03:43 PM
Aug-23-2020 03:55 PM
Aug-17-2020 07:42 AM
warrenjo46 wrote:
I decided I would like to have 120 AC available in my motorhome when I am not on shore power without running the generator. I bought a 2500 Watt inverter on line and a 50 amp automatic transfer switch. Installing the inverter and the transfer switch became complicated due to space considerations.
I decided I could install just the inverter but I wanted to make absolutely certain I did not connect the inverter and shore power or generator at the same time. I know that would not be a happy event. But I wanted the inverter to power outlets inside the MH. I needed a way to wire the inverter into the AC system of the MH that would be fool proof. That is why the automatic transfer switch seemed necessary.
I have an epiphany at 3:00 an. Just install the inverter in the compartment with the 50 amp shore power cord. Use a 50 to 30 amp adapter and 30 to 20 amp adapter to connect the shore power cord to the inverter whenever I disconnect the shore power. That way I cannot connect the shore power and the inverter at the same. The automatic transfer switch already in the MH will insure that the generator will not connect when the inverter is providing AC.
I am returning the new automatic transfer switch I purchased for this installation and saving $150.
Aug-17-2020 04:07 AM
Aug-17-2020 03:31 AM
