โNov-02-2015 07:33 PM
โNov-05-2015 06:32 AM
โNov-03-2015 08:28 AM
rgatijnet1 wrote:
Are you sure double sided tape was used? We had a mirror attached to the wall with the black mirror adhesive, which is designed to fasten mirrors to walls. It is a black adhesive that comes in a caulking tube. In our coach we taped the mirror with duct tape, as suggested, and then broke it and removed the pieces with a putty knife. Not an easy process.
โNov-03-2015 08:23 AM
โNov-03-2015 06:31 AM
โNov-03-2015 02:48 AM
โNov-03-2015 01:57 AM
โNov-02-2015 10:36 PM
โNov-02-2015 10:32 PM
Ray & June wrote:
If you can get dental floss around the tape, it will cut through the tape. Takes some work and use gloves to hold the dental floss. After the mirror is off, roll as much of the remainder of the tape off as possible then use "Goo Gone" to remove the adhesive that is left.
โNov-02-2015 08:35 PM
โNov-02-2015 08:28 PM
