Mar-21-2021 05:48 AM
Mar-21-2021 03:33 PM
Mar-21-2021 01:37 PM
time2roll wrote:
Honestly I prefer separate components for this very reason. For $150 (link above) you can have a converter to work alongside the inverter/charger that no longer charges. Put the higher rated charger money toward the new converter and just move forward. If the inverter stops inverting replace with a stand alone inverter and separate transfer switch. Either way I am sure you will be back on the road soon.
Mar-21-2021 12:57 PM
Mar-21-2021 12:39 PM
time2roll wrote:FloridaRosebud wrote:Yes about any battery charger is fine to keep your battery up and use the RV is fine. I recommend 5+ amps rated if spending money but 20+ amps is better if you will be using the RV.
Again, I'm not asking folks to help me fix this. I just had the simple question in my OP about running just a charger for awhile based on my situation. I thought I was clear.
Sorry, we try to fix everything around here 😉
Everything is slow right now. I recently shipped a programmer for replacement. (not Xantrex) First class mail was 2-3 days actually took 28 days and then no access due to snow storm. Took another week. Then another 10 days to process and return. I feel your pain. Could ask for a tracking number.
Mar-21-2021 12:31 PM
theoldwizard1 wrote:FloridaRosebud wrote:
If the budget would allow I'd put in a new inverter/charger and be done, and let everyone know of the poor customer service Xantrex has. Right now I have a 12V trickle charger set up to charge the batteries when on shore power or on genny and I want to be rid of that before we start our camping this year.
Do it once and do it right. (Or ... you will only cry once !)
Get rid of that Xantrex inverter/charger and buy a good inverter(pure sine wave, yours is not)/charger/automatic transfer switch.
Mar-21-2021 11:08 AM
Mar-21-2021 10:33 AM
Mar-21-2021 10:14 AM
Bud
USAF Retired
Pace Arrow
Mar-21-2021 09:41 AM
dougrainer wrote:
Xantrex does not have poor service. I have been dealing with them for 30 years. From when they were Heart and Trace. Xantrex is the company from the Heart/Trace merger. What they do have is disdain for so called Techs and Service centers that do not install the correct product for the applications. NOT installed to spec or they have a problem with the customer or Service Center NOT giving them adequate info and they will not just replace parts or complete Inverter/Chargers.
NOW, I take YOU to task. You stated just a 1000 watt Xantrex. You then repost and state you either had a 458 or you are installing a 458. Now, the 458 series is a 2000 or 2500 watt Inverter/Charger, NOT A 1000 WATT. So, from your 2 posts, you could not adequately explain your problem and what was done to your RV. We still don't know. So, how is Xantrex supposed to get to a resolution when you cannot even post a easy description of your problem? Doug
Mar-21-2021 09:05 AM
Bud
USAF Retired
Pace Arrow
Mar-21-2021 09:03 AM
Mar-21-2021 08:32 AM
Mar-21-2021 08:03 AM
Mar-21-2021 07:55 AM
