โApr-25-2021 05:50 AM
โMay-05-2021 08:49 AM
phil-t wrote:
Common - yes. We have 2010 Vista 32k on a '09 F53 Chassis. Big deal if there was a major change in the chassis - like from 5sp to 6sp auto trans. Or, V10 to V8.
โMay-05-2021 08:40 AM
โMay-05-2021 08:13 AM
BFL13 wrote:Interesting article, but I do see that it is pretty simple to change out the 1G/2G alternator with a 3G, so the idea that the alternator would be the deciding factor in whether or not to purchase a particular RV is unlikely, at least from my perspective, although yours may be different. I also see nothing in the article (other than the one picture caption) mentioning fires. If it was common or "infamous", as you suggest, I'd expect the article itself would mention it in the text.
"A 2G alternator's biggest issue: an under-capacity rectifier and power connector (A). The connection and large, hollow case cavity were corrosion-prone, which increased resistance, causing voltage drops and heat build-up. Result: early unit failure, and even electrical fires"
https://www.hotrod.com/articles/install-high-output-ford-3g-alternator-older-fords/
According to that, the 3G came out in the 94s, not the 92s like I said. So that means you could not spot a 92 by its headlight shape, etc and know it has a 3G. If the 94 C has a 93 chassis with a 2G, that would be a problem for me, but it is all history now.
I do imagine the same sort of thing can be happening with more recent model years.
โMay-04-2021 03:37 PM
โMay-04-2021 02:32 PM
BFL13 wrote:Hmmmm, this is the first I've heard of alternator fires being common or infamous. Neither of mine had issues ('79 & '88...oops; '87 :)), and replacing an alternator with a better unit would likely be relatively inexpensive. So I'm not saying that an alternator is not relevant, just that it wouldn't be a "waste of time".
" I would suggest no one would actually consider a lesser alternator as "waste of time" on a used RV, as you suggest.."
The 1991 Fords and earlier had a bad type of alternator that was infamous for catching fire for some unlucky owners. It also has low amps, which hinders "alternator charging" of the House batteries. The 92s got a newer, better, higher amp alternator, so it is important in that case.
(This was all discussed a while ago on Tech Issues with Mex supplying the gory details on the 91's alternator fires.) My 91 has that alternator, but it is doing ok so far. Fingers crossed.
Doesn't matter now of course, but I thought it might be the same thing with new "generation" changes that matter. AFAIK there are some recent changes to alternator regulation that also affect House charging, so people are getting DC-DC chargers. I don't know what chassis years are involved, but it could matter to some buyers perhaps.
โMay-03-2021 07:41 PM
โMay-03-2021 05:17 PM
โMay-03-2021 02:14 PM
โApr-27-2021 06:12 PM
klutchdust wrote:
"" so you have to advertise it according to the correct generation/year.""
You sell it based on what the Title says, you purchased it based on what the title says. If the finisher/manufacturer titled the vehicle as a 2001 2003 whatever THAT is the year of the vehicle. period.
Not on what the headlights look like. The seller cannot change what is on the title, the laws concerning this are very clear. And those that wonder why DMV gets confused?
Good day.
โApr-27-2021 06:44 AM
โApr-26-2021 05:55 PM
โApr-26-2021 07:35 AM
ferndaleflyer wrote:
Is everyone in CA this ignorant of what goes on in the rest of the world? Come on man!
โApr-26-2021 06:54 AM
โApr-25-2021 09:57 PM
toedtoes wrote:klutchdust wrote:ferndaleflyer wrote:
You might think different if you think you bought a new one and when you register your brand new $230,000+ coach it is 2 years old and you haven't even used it yet.
You did buy a new coach. The chassis has been sitting waiting for the house to be built. The date it is completed is the registered date of the vehicle and on the title. If the states listened to federal law then there would be less confusion. I see no conspiracy or hiding the facts here, it's a common practice.
You buy a 2021 and it's on a 2020 chassis the title says its a 2021 . You sell it it's a 2021. kapeesh?
This is the problem. Very few rigs are properly registered. The state DMVs will automatically go by the chassis VIN, so unless you are aware and are planned to fight it and get them to correct the model year, that 2021 is registered as a 2020. And you have to sell it as a 2020.
