Jackknife sofa
gboles01
I am looking for a Winnebago 20 x 60 Jackknife sofa. I bought my Class c used and it had an aftermarket reclining loveseat that was too large and heavy for the slide out. Buying a new sofa from a Winnebago parts supplier is prohibitively expensive.
2 REPLIES 2
Skid_Row_Joe
Go with a Villa brand. That's the upgrade when choosing one.
bobndot
Make sure whatever you buy fits in the provided space as well as the through the door.
https://www.recpro.com/recpro-charles-60-rv-jackknife-sleeper-sofa/?gclid=Cj0KCQiAvc_xBRCYARIsAC5QT9...
Compare prices from RP as well as Etrailer . Once the chairs are removed I assume you will have a clear and empty space with no water tank or anything else to interfere with a new sofa install.
The REC Pro sofa fits in a 22" rv door.
Use your google or servers search bar and type in
'rv.net, jacknife sofa'
you will get better results than trying to use the rvnet search bar.
