Keeping toad battery charged
getgoin
Hello All,
Getting things set up to hit the road. I have the 'Patriot' aux brake system set up in a Subaru Forester. I would like to disable the steering lock thus no key and minimize battery draw. Not as easy as it appears. So, I figure why not charge the toad battery as we go. There's kits out there and from what I see they do not use the existing + - off the seven blade motorhome socket. This seems a bit nuts to have to run yet two more wires to accomplish charging of the toad.
The kid next door offered to disable the steering lock....No thanks..
Any info on this would be great.
Mike
Mikestatland@gmail.com
8 REPLIES 8
getgoin
So, seven blade, on Winnebago, to 6 round should put me in charge :)....lights are wired, brake is Patriot wireless, pick up +/- (#8's) and I'm set.
Did I tell you I hate touch screens.
Thank fellas
Mike
DSDP_Don
"getgoin".....I would supply power to the toad as stated above, using your 7 pin cable. Years ago, I bought one of those pre made charging systems. Not only do you have to run additional wires outside the umbilical, they used some really cheesy connectors for that second set of wires.
Fuse at both ends as "wolfe 10" suggested, because your wire is HOT at both ends, even if one or the other end is disconnected.
Don & Mary
2019 Newmar Dutch Star 4018 - All Electric
2019 Ford Raptor Crew Cab
Gonzo42
Brake Buddy sells a battery charge maintainer which includes an isolation diode and fuse. The 7-pin connector should have one pin which is used either for the electric brakes on a trailer or for +12V to your toad.
MOTHER SHIP Winnebago View 24H (2007 Dodge Sprinter 3500 Chassis, 2008 Body)3.0 L M-B Diesel V6 bought used with 24K miles. Toad: ROCKY the Flying Squirrel.
wolfe10
Mike,
No, your toad and coach battery both accept/work with the same charge voltage so no voltage-reducing isolator is necessary or even desired.
Here is how to do it:
In-line fuse at both coach chassis battery and toad battery. 8 gauge wire from each battery to either separate plug or incorporate it into a toad plug with more prongs.
You will also run an 8 gauge wire from coach chassis ground to toad battery negative. Can use a heavy gauge separate 2 wire connector or as mentioned above incorporate it into a male/female toad plug with more prongs.
If you often dry camp and sometimes do not disconnect the toad electrical connection, the above set up can continue to drain chassis battery. An easy modification is to use a 40 amp relay (under $10 at any auto parts house). Come off the chassis battery, through the in-line fuse to the relay. Use an ignition hot source to close the relay to send power to the toad. Now, it will only charge when the coach ignition is on.
If you do it yourself, total cost should be under $25.
Brett Wolfe
Ex: 2003 Alpine 38'FDDS
Ex: 1997 Safari 35'
Ex: 1993 Foretravel U240
getgoin
Scott, on simply running a wire to the battery should an isolator be in that line, or a charge controller? It would seem the toad battery could boil out due to over charging.
Thanks for the reply
Mike
J-Rooster
Like Scott said run a wire from your coach batteries to your toad! Constant charge!!
rdmike
What I do. When I get to an RV park, when setting up, I start the toad, and let it idle. I level the coach, slides out, hook up water, electric, dump hose etc. Shut off toad. Never had a problem but once where I did not start and left key on all night. I now have 24' jumpers in case I need to jump the toad without unhitching. 10 minutes of idling seems to charge it fine. I hope this helps.
Fleetwood Providence 39L
Ford Fiesta Toad
Retired, spending our winters in Thailand / spring - fall traveling the great USA
FIRE_UP
getgoin wrote:
Hello All,
Mike
get going,
Is there some reason why you prefer not to use any of the un-used wires in the 7 pin connector at the rear of the coach? That's what about 97% of the RVers do. It's clean, it's simple and, the best part, it's already there. You just have to make sure that you use the correct one and, continue it on from behind the toads plug, up to the toads positive battery post, through a fuse. DONE!
Scott
Scott and Karla
SDFD RETIRED
KI60ND
