Leak from windshield
lj2654
I have been trying to find where water is leaking in my coach. Thought it was passenger window, so I removed it and cleaned and used new butyl tape to reinstall it. Still have a leak and think from the top of windshield gasket. Is there a repair facility on West Coast of Florida for these type of repairs?
2001 Beaver Contessa Naples 40
2012 Cadillac Srx
retired AirForce 1979-1992
7 REPLIES 7
Canadian_Rainbi
wny_pat wrote:
Have you checked the marker lights about the windshield? This is a major source of cab leaks in both motorhomes and heavy trucks.
That was our problem. Though we (nor the tech) could really see a "for sure" problem, the tech resealed the clearance lights and we haven't had a leak for the last 14,000 kilometers.
msmith1199
And here's the problem with leaks; they aren't always where you see them. Water stains on the ceiling may be from a leak 15 feet away. Water can run in mysterious ways.
2021 Nexus Viper 27V. Class B+
2019 Ford Ranger 4x4
retired4fun2002
A few years ago, I had a leak, thought it was the top of my window, but was also advised to check my lights and seal around them. Someone told me to go to West Marine and get a bottle of Captain Claxton's leak sealer. It is a small bottle, milky like substance, and works thru capillary action, finding the leaks as it goes and filling them; like soldering. I haven't had a problem since then. Safe travels.
crasster
You can also always seal off the coach tight with plastic, place a fan blowing out, and a smoke can around the outside of the coach. If it sucks into the coach, you know you have a potential leak.
4 whopping cylinders on Toyota RV's. Talk about great getting good MPG. Also I have a very light foot on the pedal. I followed some MPG advice on Livingpress.com and I now get 22 MPG! Not bad for a home on wheels.
koda55
We thought we had a front window leak. After a few sealings we discovered it was the dash lifting up. It was not glued or bolted down. It would allow water in when we were traveling down the road in the rain. I put sealant under the dash and put some one inch screws in. No more water leak.
lj2654
No I haven't but will do that!
2012 Cadillac Srx
wny_pat1
โ€œAll journeys have secret destinations of which the traveler is unaware.โ€
