Leisure freedom 1997
SEWRIGHT33
Just purchased and wonder what the thing is on the drivers ßide will in back for earplugs.
Also the fridge freezer works great but the fridge itself only goes to 45 degrees
Any help would be g2rsatly appreciated
Ann
LOVE CLASS Bs
5 REPLIES 5
Sherwood
We have a 98 that is probably similar to yours. The black box on the wall is a remote speaker for the TV. Our headset that plugs in there did not work but we use that rear speaker. With it on, the speaker in the TV itself is muted. Someone can sit in the back, listen to that speaker with a good view of the TV, and another person can be doing something else on the reversed front seat without needing to listen to the TV.
thriftydutch
Is it a propane or 12v-120v fridge
1990 L.E.R. Dodge B 250 Class B 17'
midnightsadie
put a bungee cord across the frig door see if temp drops. door gasket shot.
gbopp
How long did you have the refrigerator running?
The 21 year old refrigerator in our 96 Southwind takes about 1 1/2 days to get the refrigerator temp down. The freezer works great and quickly.
Did you set it to a lower temperature?
I can't help you with the earplug question.
Lwiddis
After 30 years you may need a new fridge...BUT try a battery run RV fridge fan first. Could be an air circulation issue.
