leveling
backhoemike
i tried to park on uneven site the passenger side of coach was probably 8 inch lower, i scotched this side of coach and put 6x6 blocks to keep from extending so far, my problem started when it lifted it too far and my tires came off the ground which tires isnt scotched any longer and it rolled off the blocks. the feet stuck in the ground , luckily i have retracted and not bent any stablizers , but when it retracted it left the feet and springs in the dirt and gravel. Anyone know a james bond trick for getting the feet back on the cylinders, I am not sure i can do this by myself?
17 REPLIES 17
backhoemike
40' Newmar London aire with HWH levelers, i got the levelers retracted but the round foot with the 2 springs stayed in the ground i pryed them out and they are just hangning but needs stretched out and put back on the bottom of the prick..
happy-2
what make of rv? year and what brand of levelers
happy-2
could you drive up on some blocks enough to get the pads off the ground and try to retract
