Light Bulb Dilema
Pastorricks
The bulb(s) are out on the rear-ender brake light on 99 G. B. I can get the assembly out but I can't open it to get at the bulb. Any suggestions?
9 REPLIES 9
wa8yxm
Does it look like this one?
Sealed lamp assembly at Etrailer.com
That's what I have and as I said it is sealed.
FIRE_UP
Just wondering,
What in the world is a "Rear-ender" brake light? Are you speaking of the "third" brake light. On many chassis builders, or, manufacturers, the "third" brake light is called the CHMSL. Or, Chassis High Mount Stop Light. And, that light is controlled entirely separate of the standard brake lights. That means it has a totally separate fuse too. So, to begin with, I'd check for that "CHMSL" fuse on your 12v fuse panel for chassis ops.
Scott
Scott and Karla
SDFD RETIRED
2004 Itasca Horizon, 36GD Slate Blue 330 CAT
2011 GMC Sierra 1500 Ext Cab 4x4 Toad
2008 Caliente Red LVL II GL 1800 Goldwing
KI60ND
wa8yxm
THe Tail/stop/turn lights on my Rig are about 4" (I'm not measuring) round plastic shells. There is a 3 pin plug that plugs into the back of 'em (Only 2 on the back up light) they are seated in a rubber ring.
If yours are like this. they are a sealed unit. You can get LED replacements at most any decent truck stop. I did
1492
Moderator
Moderator
Moved from Forum Posting Help and Support
SidecarFlip
Planned obsolence
2015 Backpack SS1500
1997 Ford 7.3 OBS 4x4 CC LB
DutchmenSport
I recently had the bulb go out on my utility trailer. I couldn't pop the lense off, so I removed the entire assembly. I took to an automotive parts shop and they guy said they don't come apart. I had to buy the entire assembly.... ugg! He said I could break it and try to glue it back, but it probably would not last.
I bought the new assembly, something like $10.00. Popped it back in and working fine ever since.
Pastorricks
Midnightsadie, that was my impression. Thank you.
drsteve
What kind of vehicle is this?
2006 Silverado 1500HD Crew Cab 2WD 6.0L 3.73 8600 GVWR
2018 Coachmen Catalina Legacy Edition 223RBS
1991 Palomino Filly PUP
midnightsadie
SOME ARE SEALED YOU GOTTA BUY THE HOLE LIGHT.
