Jun-08-2017 06:33 PM
Oct-07-2020 01:17 PM
ng2951 wrote:
Not according the Lippert video. On the video they show only lubing from outside. Then their tech says after lubing the outside coupler, "do the same procedure on the inside..." it is at 2:05 into this video.
https://youtu.be/gXw9I_DoAvI
Don't care what the Video shows...Doug
Mark wrote:No that does not sound normal to me.
I have a 2011 Holiday Rambler vacationer with Schwintech (sp?) slides. Mine squeak in and out. AND when the big slide is nearing full extention it goes really slow. When I put it in, it almost doesn't move then SLOWLY comes in about a foot before going faster. I'm afraid the motor will burn out eventually? What can I do, or is it normal? Thanks Mark
Oct-01-2020 04:24 AM
Don't care what the Video shows. You need to understand that for years LCI stated to NOT install any lube on this system. Then at a Training class at our dealership years ago, the LCI Trainer also stated NO LUBE AT ALL. I then showed him LCI's You Tube video that you list and he was very surprised. I have probably replaced at least 50 sets or more of the complete rack system over the years as well as rebuilt a few. I KNOW where the parts are that need the Lube. And those parts are easily lubed from the outside IF you know what you are doing. Doug
Sep-28-2020 08:16 AM
Sep-27-2020 09:18 PM
Sep-26-2020 04:07 PM
ng2951 wrote:...The Red tube is more than long enough to get to the roller and nylon block assbly...Not always. If the interior wall is to close you cannot get the lube can in the right position to apply.
I could lube 7 of the 8 bearing gibb assy. I would need arms almost a foot longer to reach the bottom bearing gibb assy.
Sep-25-2020 07:36 PM
Sep-25-2020 05:49 AM
Sep-24-2020 08:06 AM
Jun-09-2017 02:56 AM
