location of cigar liter fuse
EPeterman
I have a 2000 Discovery mod 37v. I have checked the cigar lighter power feed to the fire wall and found no fuse and no power Where do I look next the wires are heavy guage and in a protective plastic conduit, does this go to the battery control box???
2 REPLIES 2
wny_pat1
You got some good clues here: https://www.rv.net/forum/index.cfm/fuseaction/thread/tid/27083795.cfm
I would normally just follow the wire under the dash to where ever it terminates.
โ€œAll journeys have secret destinations of which the traveler is unaware.โ€
sch911
It would really help if you posted the chassis make? This what will determine where that fuse is!
OEM Auto Engineer- Embedded Software Team
09 Holiday Rambler Endeavor 41SKQ Cummins ISL
2012 Jeep Grand Cherokee Limited Toad
