Location of power seats fuse
hermelv
Had to replace the fuse for the power seats in our 2006 LTV. When I removed the passenger seat to refill the house battery, I moved the seat to the front to gain access to the rear bolts. Doing so, I accidentally pulled the orange and black wires connected to the power seat switch upfront. The live wire must have touched metal and caused the fuse to blow out. The fuse location is not indicated anywhere and after removing every fuse under the driver's seat, I noticed that fuse # 10 (a 20 amp fuse) was blown. It was identified by the manufacturer as the Air Ride Compressor fuse. It obviously serves a dual purpose as it also is the power seats fuse. I am posting this info in case this happens to someone else
0 REPLIES 0
