Low Hot Water Pressure
revump
I have an 06 Alfa See Ya. In Quartzsite, I tried to get one more day before filling up with fresh water but I let the pump start sputtering. Now, I have very low hot water pressure. It seems to be okay when I have shore water ... any ideas?
Bob
8 REPLIES 8
revump
I am now
tropical36 wrote:
revump wrote:
The cold side had good pressure ... found a faucet and put shore power to the water system ... must have had an air pocket somewhere ... cleared the system out and we have great pressure on both hot and cold sides now ... learn not to let the tank get so low
And you're satisfied with the pump pressure (no outside connection) when on the tank for both C and H as well, correct?
Bob
tropical36
"We are often so caught up in our destination that we forget to appreciate the journey."
07 Revolution LE 40E_Spartan MM_06 400HP C9 CAT_Allison 3000.
Dinghy_2010 Jeep Wrangler JKU ISLANDER.
1998 36ft. National Tropi-Cal Chevy Model 6350 (Sold)
Tinstar
Opps, deleted, didn't see you got it repaired.
:CNever pass up a chance to go somewhere:C
Les_Balty
Sometimes it's something really simple. Check the screen on the pump for sediment/hard water deposits. (Aerators at the faucets too) Hope it's an easy fix for more enjoyment.
Les Balty
revump
Bob
Pass42
tank empty?? pump sputtering sounds like no water to draw... how is the cold water side???
2017 Montana High Country 375FL
2015 Ram 2500 Heavy Duty, Cummins 6.7, factory tow package, factory snow plow prep package
tropical36
Pump maybe has lost it's prime or sucking air. Try disassembly, cleaning, some silicone on the surfaces and then tighten everything evenly and well upon re-assembly.
John_Joey
Maybe a defective hot water check valve.
Thereโ€™s no fool, like an old fool.
