Lubing in wall slide outs
RodLyle
The show on YouTube how to lube in wall slide outs...no problem from outside the coach ...but when I want to get other side I must go in coach but ti blocked by wall, cabinet work etc...suggestions
Thx
2 REPLIES 2
ArchHoagland
Going on 15 years and haven't lubed mine yet.
Have made it 95,000 miles and 290 RV parks so far with no ill effects.
How often should you lube them?
2004 Monaco La Palma 36DBD
Workhorse W22 8.1 Gas Allison 1000, 7.1 mpg
2000 LEXUS RX300 FWD 22MPG 4020 LBS
US Gear Brakes
Dutch_12078
I assume you mean lubing the seals. I lube the side seals from the outside by slipping a seal lube soaked rag under the seal and sliding it along the full length. The outside of the seal is a simple wipe of course. I do the top seal from inside by bringing the slide in a few inches and slipping the rag under the seal like the side seals from outside.
Dutch
2001 GBM Landau 34' Class A
