Hello Folks,
I know that there is a topic of what I'm about to tell you but every time I search for anything that I'm looking for, it always shows 'no match'. Anyway...
I noticed yesterday that my front AC unit was dripping water inside. We have a long ceiling panel the covers the front and middle AC vents and returns. I opened the panel and water started dripping from the panel so I put down a small bucket to let it drain overnight.
This morning, I go to check everything. Our coach is designed so that the condensation from the AC units will drip down a tube under the coach. Sometimes, depending the way we are tilted, the two drain cups will fill up and spill on the roof. That is no real problem as I need to blow-out the tubes occasionally.
But, that still didn't explain the water coming inside. I checked the four bolts that hold the air unit on the roof and I could't believe how loose they were. I'm talking at least ten turns on each screw. On the roof side, the bolts stick through at least 3 inches beyond the roof bolt.
So, I check all three units and all were needing about the same amount of tightening. I cleaned the filters and roof coils while I was at it. After running the front air for a while it appears that the tightening was the issue.
After 6 years and 62,000 miles, everything needs to be checked that has a screw, bolt or nut, etc.
Safe travels!
MM.
Mr.Mark
2021.5 Pleasure Way Plateau FL Class-B on the Sprinter Chassis
2018 Mini Cooper Hardtop Coupe, 2 dr., 6-speed manual
(SOLD) 2015 Prevost Liberty Coach, 45 ft, 500 hp Volvo
(SOLD) 2008 Monaco Dynasty, 42 ft, 425 hp Cummins
