Michelin Advantage Program
clinedinstjt
Just purchased 8 Michelins XRV 305-70R22.5 through the Michelin program. Everything went well. All 8 installed with Equal in each tire was $5619.21
19 REPLIES 19
1971duster340
I've used the Michelin program twice, 2~front...8~rear. Staight forward and easy. Got about $5400 invested for 22.5s. Some of the quotes I got from dealers was double that amount. Happy, but it still hurts.
Greg
N5LFH
2007 Chariot
1BryNelson
Getting ready to put Toyo's on mine. Those Mitch's are expensive and probably made in China. I've got the Toyo's for $380 each on the vehicle.
Bry Nelson and a yet to be discovered MoHo momma. '99 Pace Arrow Vision 37ft F53 chassis (plugs tightened) Allure flooring, 15k BTU front a/c , 6-6 volt batts with 1120 watts of solar Magnum inverter Remote BMK Trace C40 2005 Ford Ranger "Toad on a pad".
JR45
That is about what I paid $4100 install $260 balance front and new valve stems (6) tires
JR
2006 Country Coach Inspire 360 40ft Genoa Designer Series Cat C9 Samsung 197 RR
Aluminum Radiator was recently replaced with a STEEL & COPPER Bolt Together Radiator w/ updated rubber mountings
SilverLeaf VMS 330
Toad--2011 Ford Edge Sport, Air Force One
:C
lryrob9301
That's $702/tire installed, where did you purchase them?
2oldman
Boy, tires are gettin' expensive.
