โMar-05-2021 10:49 AM
โMar-07-2021 11:56 AM
โMar-07-2021 06:59 AM
pianotuna wrote:Dirtyrhoades77 wrote:
As for 48v, I can see what you guys are saying, but if I go 48, I'll then have to get a 48 to 24 converter for the fridge, and that's another component, and it's $150.
My system probly won't ever go over 2000w, so I won't be outgrowing 24v, so I can't see any real advantage over 24.
Maybe 48v mini splits are easier to find at the moment? Are 48v alternators easier to find? What other advantages are there besides more headroom for expansion?
A 24 volt inverter has to carry twice the current for the same output load as a 48 volt unit.
Your fridge is already 24 volt? That's a bit rare.
I've never seen a 24 volt mini split--but that probably means when I was searching for DC powered air conditioners that the 48 volt ones 'jumped up' first.
โMar-06-2021 07:20 PM
โMar-06-2021 05:54 PM
valhalla360 wrote:pianotuna wrote:
I would jump right to a 48 volt battery bank.
Agreed, once you diverge from 12v may as well take good advantage of a higher voltage.
Also, keep in mind for the spacing, that the 12" manufacturer spec you mention is likely based on the condenser being completely outside with no other restrictions. If fresh cool air can only enter from a relatively small slot from below, it may not meet the needs. Talk to the manufacturer and explain exactly what you are doing.
โMar-06-2021 06:40 AM
โMar-05-2021 08:20 PM
โMar-05-2021 03:31 PM
โMar-05-2021 01:24 PM
valhalla360 wrote:
OK, I'll also go down the rabbit hole...how do you plan to power it if you remove the generator to place the condenser in it's spot?
โMar-05-2021 01:18 PM
whemme wrote:
And what good is a big 24V battery when Class C appliances run on 12V dc?
โMar-05-2021 01:15 PM
valhalla360 wrote:wanderingaimlessly wrote:
The ones I've seen, they mounted the outside portion on the rear of the rig to allow sufficient airflow to cool it.
Yep, check with the manufacturer for airflow and spacing requirements.
โMar-05-2021 12:45 PM
โMar-05-2021 12:18 PM
โMar-05-2021 11:52 AM
