Motorhome Chassis/Engine Maintenance & Towbar Install?
rsmithtesiusa
Where does everyone get routine maintenance done on their Motorhome Chassis and Engine? People have recommended the local RV Dealers, but based on my experience I have ZERO confidence in them. They seen barely able to do basic repairs to travel trailers much less Engine maintenance. Also need to get a towbar, light kit, and maybe supplemental brake system for a Jeep Wrangler toad.
We have a Class C on the E450 Chassis with the V-10 engine. Need basic maintenance - oil changes, Chassis Lube, Transmission and diff fluid changes etc. If you have recommendations in the Houston, TX area that would be great.
Suggestions appreciated.
Modify message
16 REPLIES 16
angler
I found a truck stop repair place to get that done. Found someone who works on the chassis I have. Lot places work on Medium Duty trucks. Just say its a E450 not an RV:). Once they realize it's the same they usually will do it.
2020 Jayco 34RSBS
2002 Tiffin Allego Bay
2010 Keystone Springdale 29bhssr
1998 Jayco Lite 244
Tyler0215
Is there a Ford truck dealer in your area?
Any heavy truck service garage can do your maintenance.
