midnightsadie wrote:
maybe a can of sea foam would fix it ,sea foam will eat gunk.
A much better cleaner is Berrymans B12 Chemtool.
But whatever you use, "a can" probably isn't the right dose; follow the instructions on the can. If the gen shares fuel with the engine, it might take several cans.
Also, how bad is the "surge" ?
I've got the same model and it flutters a little at full load.
Drops from about 120 unloaded down to 112 at full load and there it vaires about 2 Volts up and down. This is with a new carb so I assume that it is mostly normal.
And finally, before anyone pays to have a carb on an Onan cleaned, find a dealer and ask the price of a new carb. I was surprised to find that the cost is about the same.
'07 Damon Outlaw 3611
CanAm Spyder in the "trunk"
