โMar-20-2016 07:49 PM
โMar-25-2016 03:38 PM
Dakzuki wrote:
You're running AGMs with a single stage converter?
โMar-25-2016 10:38 AM
pnichols wrote:
I have a couple of these deep cycle 12V Group 31 AGM batteries in parallel under the step (the stock location as provided by Winnebago) in our Itasca 24V Class C. They're 115 amp hours each, so they provide a total of 230 amp hours. Their specified float voltage is 13.6 volts, so stock single voltage converters don't dry them out over time. Also since they're AGM, they charge faster with any voltages in the charging range than wet cell batteries do. This means that they can both be floated and charged fairly quickly using just a stock 13.6 volt RV converter. That's what we do with our RV:
http://www.fullriverbattery.com/product/batteries/DC115-12
โMar-25-2016 07:22 AM
โMar-23-2016 02:26 PM
โMar-23-2016 10:54 AM
AGC wrote:
I've read several post about changing over to a multi-stage converter. This is my first RV, do you know where the converter is located.
Will definitely look into the Progressive unit, any particular model to focus on
โMar-23-2016 10:16 AM
โMar-21-2016 10:40 AM
โMar-21-2016 10:07 AM
AGC wrote:
Dakzuki,
If I decide to change to 6V batteries, do I need to change any other components. Which 6V AGM batteries did you get
โMar-21-2016 09:25 AM
โMar-21-2016 09:13 AM
Gonzo42 wrote:
Only room under the entry steps for 2 12V in parallel.
โMar-21-2016 08:39 AM
โMar-21-2016 08:31 AM
โMar-21-2016 07:50 AM
โMar-21-2016 07:09 AM
