Need help with 1986 Ford starting harness color codes
atsrmf
I am installing an aftermarket push button starter in my Class A, and need help in identifying the wiring in the steering column. This is a 1986 Ford, and it probably has an F-350 harness.
I have identified the yellow wires as the 12v feed, but need to know which wire is start, ACC, on, ground, etc. I don't want to fry anything by experimenting, and the location of the connection block makes it impossible to take continuity tests.
https://photos.app.goo.gl/1fSRUf2yjj6dhy4C7
3 REPLIES 3
Home_Skillet
Just run a wire from the push button to the starter solenoid.
2005 Gulf Stream Conquest 31ft
BigFoot Levelers,TST in tire TPMS,Bilstein Shocks,Trans temp guage,Lowrace iWAY
atsrmf
Not in 1986
ScottG
Caution, Yellow wires (or wires with yellow tape around them) are often Airbag related.
