NEED HELP
reddfox77
This is the only place I can get real help...I have a 1993 Georgie Boy Swinger...Need a few parts and dont know where to turn..Trim above the wheel well drivers side front and parts for wipers ..its the gadget under the hood that connects to the hose for fluid...Also have a repair question...I have two antennas on top of the coach one that is not being used and hits every tree branch possible...it has caused the screws to come loose and made the rubber roof tear slightly around the base...I removed the antenna and the mounting base is still there...I tried putting eternabond tape and then coating it with dicore...tape wont stick for some reason..any way Im wanting to just removed the base and seal it..What is the best way to do this? Thanks so much guys your all top notch...
6 REPLIES 6
wa8yxm
In the forum libraries you may find links to RV-Salvage yards such as Visioner RV in (I think) KY.
Let your fingers do the walking on their CONTACT US pages and see if one of them has what you need.
luv2dsgn
Hi Reddfoxx.
There is an used RV parts junkyard/graveyard near Ocala, Fl. that I used years ago for my older popup camper parts. This guy's got it all! He ships anywhere.
As for a great mobile repair person, I found a great guy to restore the floor in my Kiwi camper at a great low price. He's just north-east of Harrisburg, Pa. (He was formerly in management w/Grumbines before they were bought out by CW.) "Bow's Mobile RV Service" located in Duncannon, Pa. 717-609-9682
reddfox77
Thank you gentlemen...I knew I could count on you...Where do I send the check?
John_Joey
GBM was bought out by Coachmen, I've had some luck getting parts through them.
Also give Colaw a call.
There’s no fool, like an old fool.
rgatijnet1
If you clean the roof surface, remove any paint oxidation, and clean with acetone, the sealant will stick.
Try here for your wiper parts: Wiper Parts
rockhillmanor
If you don't want to run around looking for parts all over town and do it yourself. I would call an RV mobile Repair.
They've seen it all and have access to parts that most can't find. AND for what you mentioned needs fixing? It would be done in a couple of hours right there where your MH is parked right now. That's what I'd do.
Call a CG near you and ask who they use for mobile repair.
