May-17-2015 05:03 PM
Jun-12-2015 06:05 AM
Jun-11-2015 08:45 PM
Jrork wrote:
Here's the last update. Once we removed the pump we found the rubber hose from the actual pump to the sending unit housing was in horrible shape and was deteriorating. The bottom of the tank had all sorts of pieces of rubber from it and what was left of the generator pick up too. It too was falling about in my hand. Swapped out the pump and shazaam, it fired right off and holds pressure versus how it use to be where the pressure would bleed off almost instantly after you turned the key off. Thanks again everyone
Jun-11-2015 08:28 PM
Jun-11-2015 07:03 PM
Jun-07-2015 08:15 AM
Wes Tausend wrote:
Another vote for seriously considering using the old sender/mount hanger assembly and just replacing the pump cartridge. Although most net searches will return a variety of brands of pump, I believe most OEM get their pumps from a root manufacturing source called Walbro (a USA pump manufacturer) and put their own sticker brand on it.
All the pump has to do is pump enough to support the HP range. Your V-10 has around 300HP and it takes a certain amount of gas to achieve that over a 4 cylinder for instance. That 300 HP puts you in the range of a common 255LPH (255 liters per hour) pump which will support up to 500HP. The excess fuel is returned via the regulator and return line, or the pump voltage is adjusted/pulsed to furnish what is needed, very little at idle, a moderate amount at mid-throttle for instances. Modern F.I. may seem complicated but it is far from rocket science and all world vehicles now use essentially the same tech for port injection (such as the V-10).
Such pump cartridges may sell direct for little over $100 and, being an OEM supplier, Walbro has always been top quality in the past.
As an example, here is a Walbro 2003 F550 V-10 pump for $108. All 2 valve V-10's are similar HP and the small-truck-only 3-valve HP are just a bit above at around 360 HP, both V-10's same size pump catagory however.
You will probably find that your Motorcraft cartridge will fit by itself if you cannibalize the new one and want to blow the big bucks on it. Otherwise you should be able to find Walbro pumps here: walbrofuelpumps.com. $99.99 with free shipping.
Good luck.
P.S.
I forgot to mention that some gas tanks when left parked for a long time (without adequate fuel submersion) tend to rust the fuel level sender which is usually part of the hanger assembly. In that case your fuel guage may be inaccurate and you will benefit from finding a new hanger, or at least proper parts to replace the fuel level indicator part.
Wes
Jun-06-2015 09:43 PM
Jun-06-2015 09:10 PM
Jun-06-2015 07:03 PM
Jun-06-2015 08:30 AM
Jrork wrote:tropical36 wrote:
You might be better off with getting an OEM replacement and hopefully you can return the one you have now. Try Amazon first, then maybe Mills supply, along with many others for a discount over your local Dealer.
Thats where my frustration is from. This IS a factory Ford Motorcraft complete pump assembly in the factory box and it won't work. Cost $600 over the others that were 1/2 the price but I figured it was worth the added expense. How much you wanna bet the aftermarket one would have been just fine and I'd be done.... 😞
Jun-05-2015 07:56 PM
Jun-05-2015 12:47 PM
Jrork wrote:
ARGH!!!! Yep, After taking measurements we opened up up the floor and sure enough, there's a nice big hole there with the fuel pump setting right there.
The bad thing is the million dollar motorcraft fuel pump I got from Rock Auto is the wrong one!!!! This chassis has 3 nipples. Probably one for the fuel to the motor, one for the fuel to the generator and then one for the return. The the motorcraft pump I have here in the box only has one nipple......
Jun-05-2015 12:23 PM
Jun-05-2015 10:54 AM
Take another look at where your holding tanks are located, as what you're saying, doesn't sound right. Obviously the black tank end is going to be directly under the toilet and the grey tank probably alongside it from either port or starboard. When replacing such, both usually have to come out just one side, so double work if your problem is with the inside tank. Not always I guess, but this I've seen.
Tropical36 for the win! I started looking closer at the bolts that hold the tank on and there was no way that we could get any tools to them and the7 built the basement compartments tight to the bolts. Only way to access them would be to cut a hole in the walls of the compartments. Given that, it made me look closer at what Tropical suggested. Aerbus had some nice covered panels in the compartment that houses the waterheater and while they were a pain to remove (just lots of screws), it provided a view between the floor of the motorhome and the "plate" that is above the chassis frame. There appears to be about 12" of space. While it's still too cramped to crawl in there and do anything, what we did find was that there appears to be a hole already cut in the plate and covered up with some insulated material. I'm betting that it is already located over the top of the sending unit. All we have to do is lift up the water tank (under the bed) and either cut a hole or possibly, there's already a hole there since Aerbus has provided a access hole on the plate. Stay tuned and wish us luck!
Jun-05-2015 10:33 AM
