No power from house batterys
pauly_boy
I'm fine with shore power but I don't seem to be getting any power from the house battery's(2). Was working. Any idea's.
Thanks Paul
9 REPLIES 9
bobndot
Hey what is this, the RV Net version of โ€˜Iโ€™ve Got A Secret ? ??
VA-Apraisr
x 2!!! This website helps everyone by posting a problem/situation and FINDING A SOLUTION!
way2roll
Navigator
Navigator
pauly boy wrote:
Problem solved. Motoring west next week. Ya Who
What was the solution? Reporting back can help others.
pauly_boy
bobndot
cencerrita
Thanks Paul
Do you have a generator and is that supplying house power.
www.cencerrita.comNow living in Pembrokeshire, Wales, UK. See our web site for US travels and books www.cencerrita.com
pauly_boy
Thank you gentlemen . I'll try both. Fingers crossed!
bobndot
If the switch is on then i would ,
Remove the cables to the battery and check the voltage. 12.6 - 12.8 range would be a fully charged battery.
If there is no 12v power once you replace the cables, i would check the fuses and make sure the ground connection off the neg battery terminal to the chassis ground is clean.
corvettekent
Check the voltage at the house batteries. Is the battery switch turned on?
2022 Silverado 3500 High Country CC/LB, SRW, L5P. B&W Companion Hitch with pucks. Hadley air horns.
2004 32' Carriage 5th wheel. 860 watts of solar MPPT, two SOK 206 ah LiFePO4 batteries. Samlex 2,000 watt Pure Sine Wave Inverter.
