oil capacity
Richert
Just bought a 2019 F450 Class C V10--how many quarts of oil should I buy to change the oil?
Blake
2019 Sunseeker
2012 Jeep Wrangler Toad
Wife in passenger seat.
6 REPLIES 6
Richert
thanks
Blake
2019 Sunseeker
jdc1
How much oil? I buy mine by the case at Costco....saves 50% over most other places...... Then I order filters from Amazon or WalMart.
DrewE
IIRC it's about six or so quarts; if you get two five-quart jugs, you'll have plenty and some left for the next oil change. There should be a Ford owner's manual for the chassis with the motorhome that has details such as that.
Beverley_Ken
Just confirm which chassis you have. Most Ford c-class MHs were built on the E-450 cutaway chassis with the 6.8L V10. (not the F450).
Here is some info for the 6.8 V10.
Ken
2006 Winnebago Outlook 29B E-450.
2012 Honda CR-V AWD
Blue Ox Aventa LX tow bar and Brake Buddy Vantage.
Ranger_Smith
From the Ford book . . .
CAPACITIES AND SPECIFICATIONS - 6.2L Capacities
WARNING: The air conditioning refrigerant system contains refrigerant under high pressure. Only qualified personnel should service the air conditioning refrigerant system. Opening the air conditioning refrigerant system can cause personal injury.
Item Capacity
Engine oil (with oil filter). 7.0 qt (6.6 L)
Engine coolant. 21.3 qt (20.2 L)
Brake fluid. Between MIN and MAX on brake fluid reservoir
Front axle. 2.7 qt (2.6 L)
Rear axle-10.5 inch with Electronic Locking 3.3โ€“3.5 qt (3.1โ€“3.3 L) Differential.
Rear axle-10.5 inch without Electronic 3.5โ€“3.6 qt (3.3โ€“3.4 L) Locking Differential.
Rear axle-Dana M300.
3.78 qt (3.58 L)
Automatic transmission fluid (6R100).
13.9 qt (13.2 L)
Automatic transmission fluid (6R140).
17.4 qt (16.5 L)
Transfer case fluid. 1.9 qt (1.8 L)
Windshield washer fluid. Fill as required
Fuel tank (incomplete vehicle, middle 26.5 gal (100.3 L) location).
Fuel tank (All except 176 inch wheelbase 34.0 gal (128.7 L) and incomplete vehicles).
Fuel tank (176 inch wheelbase). 48.0 gal (181.7 L)
Fuel tank (incomplete vehicle, aft axle 40 gal (151.4 L) location).
Where we are now
Amateur Radio Operator WW1SS . . . Flex 6500 PGXL and TGXL
Steve and Joy
2014 Itasca Suncruiser 38Q . . . 2016 Lincoln MKX
The Doodles, Abbie & Abel
Baby and Kissie the Chihuahuas and Lucy the Biewere Yorkie
MountainAir05
here you go . Put in your Vin and download since you must not have one. It will be 6 or 7qt but always to be safe and never over fill.
oil amount
