Oil filled front hubs
egh33
How can you tell looking at the sight glass on the hub. There doesn't seem to be any marks for full or low oil. It has the words minimum oil level. But it doesn't show just where the level for minimum oil level is.
My oil level is just a bit below the center of the rubber plug on the center of the hub . It is an 06 Winnebago Adventure /work horse chassis.
Thanks in advance for any ideas.
10 REPLIES 10
w4phj
When adding oil to hubs, don't forget that it takes a while for the oil level to stabilize. Don't get in a hurry, add oil and wait a while for the oil level to stabilize.
2021 Winnebago View 24J
2021 Ram pick up
2015 Jeep Wrangler Unlimited Sahara
Ham Radio Extra Class Volunteer Examiner
FAA A&P License
1969 Plymouth Road Runner
Sully2
If you have oil UP TO the CENTER of the rubber plug....you have too much in it.
Like one posted stated its like a differential. Pull the plug and when oil stops running out put the plug back in.
presently.....Coachless!...
2002 Jeep Liberty
2016 Ford Escape
egh33
Thanks a bunch. Hubs oil were up good , did not need to add any oil.
crasster
Ivylog wrote:
When you cannot see oil it's time to add till it comes out where the rubber plug goes in. Since your's is half way up the rubber plug it has plenty. Go camping.
X2. Perfect answer, especially the last sentence.
4 whopping cylinders on Toyota RV's. Talk about great getting good MPG. Also I have a very light foot on the pedal. I followed some MPG advice on Livingpress.com and I now get 22 MPG! Not bad for a home on wheels.
rvten
Go to irv2.com Workhorse owners site.
When I had my WH chassis. I beleave I kept the oil in the hubs about half full.
Used 80 or 90 weight oil.
Tom & Bonnie
Crossville, TN.
Aspect 29H 2008 Type C
Ford Flex SEL 2010
There is NO B+
Ivylog
Upgraded with a 08 HR Navigator 45’...
mike_brez
egh33 wrote:
lj2654 wrote:
If you have oil just below the rubber plug you are full. I have two lines on mine that show minimum and full.
Thanks a bunch for the info, but like I say there are no lines on mine. I bought the coach brand new, there never has been any lines on the sight glass.
It's kinda like your rear differental pull the plug and fill until it comes out of the plug hole and yer done.
1998 36 foot Country Coach Magna #5499 Single slide
Gillig chassis with a series 40
02 Ford F250 7.3 with a few mods
2015 Wrangler JKU
egh33
lj2654
2001 Beaver Contessa Naples 40
2012 Cadillac Srx
retired AirForce 1979-1992
rgatijnet1
This is from the WH manual: Oil filled hubs
Basically you pull the rubber plug from the center and fill it with oil. Any excess will run out. Put the plug back in and you are done.
