oil leak
Sir_Traveller
Hello Everyone…
I have a 2003 Ford F-53 RV
Two months ago I did an oil change, the recommended amount was 6 quarts, but most forums recommend adding 5 quarts fits then check the level and add as needed. So I added 5 quarts but got busy and forgot about checking the level and adding more till 2 weeks ago, so I checked the level and added about ¾ of quart… few days ago I noticed an oil leak, I got under the RV and saw the leak was forming around the AC compressor belt, is that normal after oil change? Does that mean I overfilled it? Could it be different type of leak? Or is it a sign of something more serious? Take into consideration I have not drove or moved the RV, I have been hooked up for the last 5 months
20 REPLIES 20
CA_Traveler
A/C compressors do contain some oil, but make sure the leak isn't above the pully. Are you sure you didn't spill some oil during the oil change?
The belt to the right appears dry which might suggest the leak occurred since the engine was last run because the belt on the compressor is wet.
2014 Grand Cherokee Overland
Bob
MountainAir05
Have you been running the engine. If not then it got spilled when you put the oil in if you put it in at the engine. As stated engine oil does not go thru Compressor. Is the oil drip clear or the color of engine oil.
Sir_Traveller
Sir_Traveller
https://hosting.photobucket.com/images/i/ryadh1980/IMG_9976.JPG
https://hosting.photobucket.com/images/i/ryadh1980/IMG_9979.JPG
https://hosting.photobucket.com/images/i/ryadh1980/IMG_9980.JPG
https://hosting.photobucket.com/images/i/ryadh1980/IMG_9981.JPG
John_Wayne
Engine oil does not flow through the AC compressor so if it is leaking from the compressor it is fluid used for the AC.
John & Carol Life members
01 31'Sea View single slide, F53 V-10 with 134,000 miles and counting.
2012 Jeep Liberty Smi brake system
Security by Bentley
God Bless
KF6HCH
Ranger_Smith
A picture might help
Where we are now
Amateur Radio Operator WW1SS . . . Flex 6500 PGXL and TGXL
Steve and Joy
2014 Itasca Suncruiser 38Q . . . 2016 Lincoln MKX
The Doodles, Abbie & Abel
Baby and Kissie the Chihuahuas and Lucy the Biewere Yorkie
