Old Vs New Rig
familyguy819
Hello, I wanted to get some opinions on whether we keep the rig we have, give it some TLC or spend some money on something newer. What we have: 1999 32’ Fleetwood Bounder, 6.8L V10, F53 Chassis What we are looking to do: Pulling a 20’ enclosed with quads (5-6x a year),local camping and 2-3 long distance (3000) mile road trips per year. It’s the gen 1 V10 so its a bit on the underpowered side. So far no real issues engine or transmission wise that has ever left us stranded. My question to the forum is as follows: Is it worth it to keep our payed off rig, put a few dollars into it cosmetically(graphics and carpet) and mechanically, ( Banks kit,deep transmission pan with cooling fins, and a good round of preventative maintenance). Or spend the money on a newer rig with low miles and enjoy the reliability and added power. I understand this will ultimately come down to me, mainly wanted to get an idea of how reliable the F53/V10 will be for how much longer or should I save myself the headache and spend the cash. Thanks in advance for the replies:)
18 REPLIES 18
crasster
I'd redo the old. Until these MFG's start making a better product out of Indiana, I'd go on a buy strike.
4 whopping cylinders on Toyota RV's. Talk about great getting good MPG. Also I have a very light foot on the pedal. I followed some MPG advice on Livingpress.com and I now get 22 MPG! Not bad for a home on wheels.
falconbrother
If it's reliable I'd keep it. You can buy a newer rig and end up with a lemon and be sore. I can't speak to the power. Perhaps a Banks kit would get you where you want to be. Me, I'm just not in a hurry and I don't mind kicking up the RPMs to climb a mountain. I pulled my Harley behind my old rig but, it had the GM 454. It did just fine as far as power goes. I understand that the V-10s were built to get their power at higher RPMs.
Really, it comes down to what you want to do. Me, if I knew the one I had was trustworthy I'd stick to it. I have known a few folks that bought new/newer and ended up mad because the one they traded was good and the one they got was a tub..
KangaBunnyRoux
My first rig was 19 years old (1985 purchased in 04). Second rig was 22 years old (1997 purchased 2018) with roughly same mileage. 34K miles. First one was updated with all new rubber, tires, hoses, belts and fluids when I bought her. She ran like a champ and I just kept the roof sealed, replaced stove and coach water pump. Had her 16 years camping on weekends and holidays, she sat for 2 and a tree ended her life. Fell right on the bed over cab portion. My 1997 Holiday Rambler was a great build year on same chassis as yours (F53), with Ford 460 engine. Both were high quality builds. I really like Bounders and the ones I know of were well equipped. Their paint was a bit rough in 80s and early 90s and they chalked and faded to a pinkish color but that can be restored using Zep floor sealer and polish. I've used that these past 7 years on both and it is a no rub, no buff, no yellow finish if you follow the correct applications of 4 light coats. I think the V10 can pull 5K total...but loading it with 5K exceeds the trailer hitch rating. Now if you can add electric brakes to the trailer I think you may be able to do it. My very first pull behind was a 69 Barth Junior (bought in 1996). Those electric brakes were wonderful and I actually used them to slow me coming down grades in Wyoming. I would not want 10K pounds pushing me from the rear. I will say the one thing drastically requiring replacement in my 97 Holiday Rambler was every brake component. And that was pricey. $3676 plus an additional 1K in other stuff. The rubber lines rotted from within. It stopped fine in the neighborhood. But above 45 to 55 mph? I roasted all the components. That was not a happy day. But now I have great confidence in the brakes. I freshened up the interior for 1K. I think I now have 36K miles on the engine and transmission. Plenty of life left. When I get it registered and inspected next I will replace transmission and coolant. Otherwise I've only had 2 oil changes, one cracked pipe and a ruined valve due to the freeze in Texas. I think they were much better built in the 90s.
familyguy819
I appreciate the replies And insight from everyone. We’re going to keep the Bounder and give it some TLC.
ArchHoagland
Better the Devil you know than the Devil you don't know.
Keep it.
2004 Monaco La Palma 36DBD
Workhorse W22 8.1 Gas Allison 1000, 7.1 mpg
2000 LEXUS RX300 FWD 22MPG 4020 LBS
US Gear Brakes
familyguy819
1320Fastback wrote:
Seeing your local where is you your camping and riding? We alternate between Glamis, Pole Line Road, North Marina Dive and Octillio.
Also I vote for keeping what you have. It's paid off, in a known condition and one could argue older is simpler and more reliable.
The known condition item is a huge factor. Buying a used coach can be a real roll of the dice depending on who owned it prior. Thanks for the reply.
familyguy819
RLS7201 wrote:
If you feel that you 99 coach is in good repair, then go for the face lift.
Don't worry about the transmission heat. Ford did a good job of cooling, and heating when necessary, the transmission fluid.
The Banks Power Pack is a good investment. You'll like the results.
With you towing at the max, you may want to look at the rear frame extensions. Some of them are scary and could use some added metal and weld.
My graphics were old and tired. I elected to replace the old graphics with paint. Taping before the paint was long and tiring.
Richard
Thanks For the reply. Along the lines of what I’ve been thinking as well. It’s been a great coach. Sure is nice not having a payment. I’ve been looking into paint or new graphics,
not sure which way I would go.
doxiemom11
We have a 2000 V10 36' and will put money into this long before we would buy new/er. We have a quality build and have had no major issues in the 10 years we have owned it. Floorplan works great for us. We'll just keep this paid off one, and you will probably be happier with yours, as long as you like your coach.
1320Fastback
1992 D250 Cummins 5psd
2005 Forest River T26 Toy Hauler
Bionic_Man
My folks had a early 00's National Sea Breeze. Somewhere around 34'. Bought new, put around 100k on it, trouble free miles. Sold it, got a DP, kept it a few years, life happens, sold it, ended up buying basically the exact same Sea Breeze that was owned by one of their friends. 2nd time around engine has been fine, but the tranny went out with around 50k.
Folks tow a Wrangler Unlimited, the MH they bought was used to tow a Grand Cherokee.
Power is what I would describe as anemic. They are 25 - 30 MPH going over the passes in Colorado. Wouldn't be enough for me, but dad seems to be ok with it. I guess it is all bout expectations.
2012 RAM 3500 Laramie Longhorn DRW CC 4x4 Max Tow, Cummins HO, 60 gallon RDS aux fuel tank, Reese 18k Elite hitch
2003 Dodge Ram 3500 QC SB 4x4 Cummins HO NV5600 with Smarty JR, Jacobs EB (sold)
2002 Gulf Stream Sea Hawk 29FRB with Honda EV6010
PastorCharlie
This topic, old vs. new, reminds me of the question; "Would you rather have an old five or a new one?"
Blackdiamond
I have basically the same set up, my 03' southwind V10 and a 20ft enclosed with a rhino and 3 dirt bikes.
Would I like more power, yup, absolutely. Is it really needed, no it tows fine a couple places up steep grades it is going slow, but no slower than the semi-trucks, faster than some.
To get more power you would need to go with a 06' or newer with a 5 speed trans or much newer 2016 for the 6 speed. To me its not worth it, these engines go 200,000-300,000 miles.
Update what you have and keep that paid off coach.
03' Fleetwood Southwind 32VS
Enclosed Trailer hauling the toys
05 525 EXC KTM
15' FE350s Husqvarna/KTM
07 Rhino, long travel, 4 seater
RLS7201
Richard
95 Bounder 32H F53 460
2013 CRV Toad
2 Segways in Toad
First brake job
1941 Hudson
familyguy819
Yes 5000 was road ready.
