โSep-10-2019 12:21 PM
โSep-10-2019 09:49 PM
Ductape wrote:I saw that but couldn't make a correlation between CCA at those temps and the actual amp draw. You may be right.
I expect itโs a lot more than that. Cummins spec for starting batteries:
475 amps down to 0ยฐ F (?17ยฐ C) 650 amps down to ?20ยฐ F (?29ยฐ C).
โSep-10-2019 05:38 PM
โSep-10-2019 04:33 PM
โSep-10-2019 04:30 PM
โSep-10-2019 03:27 PM
โSep-10-2019 02:55 PM
โSep-10-2019 01:32 PM
CA Traveler wrote:
What is the expected cranking amp draw for a Onan 10K generator?
Mine is cranking slow due to excessive voltage drop on the + wire and I want to estimate what the voltage drop should be for the wire size and length. The - side uses frame ground is is OK.
โSep-10-2019 01:02 PM
