Onan Marquis 7000 - No Output Power
Cocky_Camper
My grandpaw has a 95 Pace Arrow with a Marquis Onan 7000 model 7NHMFH261050 and it has no output power.
The ATS went out a few years ago, and his RV repair guy installed him a 50amp end on the generator to plug the RV power cord straight into instead of replacing the ATS.
That worked for several years with no problems when he ran the generator. Now the generator has no output power at all. The generator starts and runs great still though.
Anyone have any ideas on anything simple that it could be for us to check?
2004 Sea Breeze by National RV - 8341
Former Coaches:
2006 Keystone Zeppeline 291 - TT
2000 Aerolite Cub F21 - Hybrid TT
1991 Coleman Pop Up
Formerly known as: hybrid_camper
10 REPLIES 10
Cocky_Camper
Dutch_12078 wrote:
Onan NHM Operator's Manual
Thanks for the link. I have looked online for the manual with no luck at all!
Former Coaches:
1991 Coleman Pop Up
The control fuse end is missing so the 10 amp fuses won't work. I need to replace holder but can't find it.
You are responding to a thread that's 5 years old. Did you have a question? if so, I suggest posting it in a new topic.
Dutch_12078
Dutch
2001 GBM Landau 34' Class A
dodge_guy
Breakers are behind the access panel on the generator.
Wife Kim
Son Brandon 17yrs
Daughter Marissa 16yrs
Dog Bailey
A bad day camping is
Sam_Spade
way2roll wrote:
Should be a breaker on the generator itself - check to see if it's tripped.
This.
And I assume you have checked to be sure that the cord is firmly plugged into the gen outlet ??
I have had good dealings with the Onan/Cummins dealer in my area.
'07 Damon Outlaw 3611
CanAm Spyder in the "trunk"
Bruce_Brown
Moderator
Moderator
Check the brushes. Years ago friends had one that would run but no output. We took it out and dropped it in my garage. Found one brush cracked. $26.00 later it was working as advertised.
Bruce & Jill Brown
2008 Kountry Star Pusher 3910
Cocky_Camper
RLS7201 wrote:
2 circuit breakers on the right side as you face the generator. Not out in the open. You'll have to look close.
Also, that generator is an NHM, not NHH..........
I have the same generator on my 95 Bounder.
Richard
You are correct with the model. I edited that. I did not see any breakers when I was out there yesterday, but I will certainly take a closer look when I go back, which will be next week as I will be out of town this weekend.
Thanks!
Former Coaches:
1991 Coleman Pop Up
RLS7201
Richard
95 Bounder 32H F53 460
2013 CRV Toad
2 Segways in Toad
First brake job
1941 Hudson
way2roll
Navigator II
Navigator II
