Onan 7000. Performing the season-end oil change yesterday, the oil filter was really hard to get off, had to use a breaker-bar on the oil-filter socket to break the filter loose. That's a really bad omen. Instead of spinning right off, I had to really work to unscrew the filter.
Once the filter was removed, I had a look at the threaded mount on the generator: all the threads are damaged and the tip, with the last couple of threads, was missing. Looked into the oil filter and there's the broken section stuck in the oil filter threads.
I am assuming that I've run into the age-old problem of dis-similar metals fusing together - the steel threads on the oil filter bonding to the aluminum threads on the generator.
In any case: now what? The generator has to come out so I can get at the damaged filter mount. But then what? If there is enough material left I might be able to clean up the remaining threads with a die. Maybe.
Has anyone had this issue? How did you fix it? can it be repaired?
1994 Bounder 32, F53, 460
