Outside Water Softener set up photo's
journey15
Does anyone have photo's of their water softener set up outside? We are in the process of planning the installation of ours that we just purchased. I am curious as to how others have theirs set up and configured. We purchased an On the Go Double Standard Softener with the 2 filter canister set up.
Thanks.
Full Timing June 2015
07 Allegro Bus 40QSP
08 Honda CRV EXL with Blue OX and US Gear Braking System
FMCA #381833
n4gnn n4hon
I Never Look Back, I'm Not Going That Way!
10 REPLIES 10
TechWriter
icanon wrote:
Thanks. Really like your set-up.
Thank you. More info on it here.
www.rvSeniorMoments.com
DISH TV for RVs
icanon
TechWriter wrote:
icanon wrote:
How often do you change the filters?
Depends. Some places have "better" water than others. Generally, I watch how "brown" the sediment filter gets. On average, at least every 6 months.
icanon wrote:
Was it expensive to do?
Sediment filters are cheap. Carbon filters not so cheap. UV replacement lights -- outrageous.
Loving wife and 2 beautiful daughters.
Chocolate Lab, Lily
2014 Dodge Ram Laramie Hemi 5.7 with 3.92
2014 Dutchmen Kodiak 290BHSL
ProPride 3P Hitch
Progressive Industries EMS-PT30C
Love my Weber Q1200
Me a Happy man on retirement!!!
TechWriter
Old-Biscuit wrote:
'TechWriter'
Is everything on water board accessible with softener/filters in place?
Yep. Water softener is plumbed so that system can be used with softener removed for recharging.
DISH TV for RVs
TechWriter
DISH TV for RVs
Bill_Satellite
I am not sure what you need photos of. I run a short water line from the spigot to the water softener and my regular hose from the water softener to the coach. Done!
I have filters internal to the coach (sediment and charcoal) but if you have no filters in place currently I would put something like a 5 micron sediment filter ahead of the softener and either a charcoal or 1 micron sediment after. A sediment filter is needed in your line somewhere in all cases (with or without a water softener), it's just a matter of how much work is involved in where you place them.
Can't we all just get along?
Old-Biscuit
Some outside examples
journey15
TechWriter
Nice setup but we do not have room inside our wetbay for all of this. That is why we have to put it outside. I wish we did.
FMCA #381833
n4gnn n4hon
Old-Biscuit
'TechWriter'
Nice install.
Have a FW so don't have room in a compartment to leave unit hooked up
Just use short hose from CG spigot to filter then short hose to softener then regular potable water hose on outlet.........either connected to 'city water' or used to fill fresh water tank.
Softener and filter sit on ground next to CG spigot.
icanon
TechWriter wrote:
My softener is inside:
A = Watts regulator
B = 10" sediment filter
C = 10" carbon filter
D = Softener
E = Flow meter
F = UV filter
Nice set-up. How often do you change the filters? Was it expensive to do? Thanks.
Chocolate Lab, Lily
ProPride 3P Hitch
Love my Weber Q1200
TechWriter
A = Watts regulator
D = Softener
E = Flow meter
F = UV filter
DISH TV for RVs
